Appliances
locanchee
Hi Aaron I have a problem with my coffe maker the red ...
Hi Aaron I have a problem with my coffe maker the red light came on I have cleaned it 3 times the red light does not go out the coffe taste very bitter thanks
ninjamice
Job Title: Product Expert
Store: Prince Albert
Re: Hi Aaron I have a problem with my coffe maker the red ...
Hi locanchee!
I was wondering what type of coffee maker do you have? Is it a Drip Brewer or a Single Cup Brewer like a Tassimo or Keurig? If you could possible reply with the Make and even better the Model number I would be more than happy to see what I can find out for you.
By the sounds of it though I would recommend visiting the store with the machine as it most likily will result in an exchange if you are within the return policy of 30 days, have a manufacturer warrenty we are able to handle (select models and makes only) or if you purchased our Product Service or Replacement Plans.
One thing to also keep in mind too is that you can always give us a call at the store as well as try contacting the manufacturer for troubleshooting.
Veronica
Prince Albert Appliances Product Expert
