Appliances
Question151833
We're having a problem with our Keurig Single Serve Coff...
We're having a problem with our Keurig Single Serve Coffee Maker (KUB70) - Platinum not priming automatically/properly without removing the water reservoir completely and then putting it back on between each brew cycle. Is there a way to fix this ?
AppliancesPE29
Job Title: Product Expert
Store: Whitby
Re: We're having a problem with our Keurig Single Serve Coff...
Hi,
Sometimes air bubbles can get caught in the hose running through the machine.  If you take the reservoir off and put it back on sometimes that can resolve the issue.  Also trying to brew just an empty cup can sometimes push the air all the way through.  You can also try cleaning the removeable insert that punctures the cup.  That should take care of the problem.  If not you may have to call keurig in order to get it repaired, they do have a 1 yr. parts and labour warranty.
Tony
Product Expert Appliances
Whitby ON
(905) 438-7950
