Can i get a replacement fob for a Command Start?
recently bought a van that has a 'Command Start' installed and of course no key fob came with  (97 Mercury Villager).  What are my options as far as a replacement?  I do have a Nordic Start installed in a Toyota, would i be able to use that fob for both cars? and if so, what's the procedure to do so?  Thanks in advance
Community Manager
Re: Can i get a replacement fob for a Command Start?
Hey, my apologies for the late reply. I will look into this for you and get back to you ASAP.
BBYBilly
Community Coordinator
No problem - Ziebart ordered one in for me $50 including programming. I sure miss the Future Shop forum. It was so much better than this one.
