Kenwood DNX6180 SKU10093244
Have an aftermarket Kenwood DNX6180 SKU 10093244.  Previous owner had Sirius Radio.  Did not renew when subscription expired.  I want to subscribe but cannot find the Radio ID.  Can't get channel 0 on the display.  Screen reads "disconnected".  Please advise.
Re: Kenwood DNX6180 SKU10093244
Sirius Radio is an optional add on to the kenwood. It sounds to me like the Sirius Radio was either removed or not installed.
If you are certain it is still installed then it could be a loose cable
Thanks for the reply.  I am sure Sirius Radio was included in the Kenwood.  The subscription was active when I purchased the RV.  Where do I look for loose cable?
Welcome to the Best Buy Plug-in forum @Sbeileenb
To find loose cables I'd start at the back of the Kenwood radio to confirm what is or is not connected. Check to see if you have the Sirius XM Connect tuner under the dash.
Can you download the owner manual of your Kenwood? It may help to confirm all the connections and peripheral equipment that was included with the unit, including a troubleshooting guide.
I'd also suggest locating the Sirius Radio antenna on the outside of your RV, to confirm that signals can be received.
Something tells me that the previous owner may have removed it for use at home.Smiley Frustrated
