Which car audio decks fit a 2007 MAZDA 5
Re: Which car audio decks fit a 2007 MAZDA 5
Hey there @Arhoops, welcome to the Best Buy Plug-in Forum.
From what I recall the 2007 Mazda 5 has an integrated system, and a dash kit is required to fit a "Double DIN" head unit, along with a dedicated wiring harness, I am unsure if an antenna adaptor is also required, to make the switch from factory head unit to an after market.
Are you planning on installing it yourself, or have it done professionaly?
