Bi-wiring vs bi-amping.
That's a notion that return often on the forum. Why some speakers have two sets of binding post and what's the difference between bi-wiring and bi-amping?
There's a picture of bi-wiring where you use two sets of cable from the amplifier and the speaker:
Trust your senses, not the numbers...
Over 6,000 post
In the "forum français".
Re: Bi-wiring vs bi-amping.
And this is a picture of bi-amping where you use two amplifiers, one for the bass section and the other for the high section of the speaker.
Over 6,000 post
Some people use the Zone 2 amplifers of their A/V Receiver to " Bi Amp " the front left and right speakers. That way you wouldn't need a second seperate amplifer to do the job.
Yes you're right but it's better to use the amplifiers of the back surround channel from a 7.1 receiver because you're sure that the gain of the two amplifier powering the same loudspeaker is matched. That's usually not the case with a zone 2 amplification circuit and with this zone 2 amplifier you can't apply bass management.
Over 6,000 post
Its exactly those rear surround channels that I assigned to Bi Amp my front L and R speakers, with bass management included on my Denon Receiver. Good Point. You have to assign these Amps as part of your Receiver setup to the L and R speakers though , or you will only get the Rear surround signals running part of your front speakers, and would miss a lot of sound ( without this Amp Assign Function ).
In fact, the capability of 7.1 receivers to bi-amp the two front speakers from the back surround amplifiers are the main reason to get that sort of receiver. Most rooms are not ideal for a 7.1 channels setup anyway.
Over 6,000 post
