- Audio
- Receiver advice
Receiver advice
06-29-2010 01:20 PM
I am looking at buying a new receiver. I'm looking for some advice on what to get based on some criteria I have.
- One HDMI cable to the TV for ALL hookups (so convert component from Wii, HDMI throughput from PS3, etc.)
- HDMI 1.4a for 3D
- TrueHD and DTS HD surround
- 7.1 channel
- Multi-room channels so I can watch a movie in one room but send audio through the ceiling speakers in the house.
I'm looking at both Futureshop and (competitor) and it seems like the only choices are almost $1000, which seems a bit high to me.
I might upgrade the speakers as well, if anyone has some ideas ![]()
Thanks!
Re: Receiver advice
06-30-2010 07:46 AM
If you want all that connectivity plus 3D plus multi-room, better open up the budget a little more.
The Pioneer VSX-1020-K lists for $799 at Future Shop, one of the better low-end options.
You could also consider the Onkyo TX-SR608 which is usually around $699, packs a little bit more power than the Pioneer but you have to look to competitors for that model as I don't believe it's carried by FS.
If you open up the pocket book, consider looking at the Denon 990 which lists for $1,699.
And remember that there are SALESMEN there, so strike a deal!
No-one will have any ideas about speakers if you don't mention what you already have. :-)
Re: Receiver advice
07-05-2010 08:01 AM
The Yamaha 6280 will also do the trick at $799.
If you are considering speakers, FutureShop has audio packages available that will save you a good chunk of change vs buying speakers and a receiver seperately.
Most of the packages are not advertised, but you can find out by going in to talk to an associate.
Re: Receiver advice
07-16-2010 03:49 PM
Also look at the Denon AVR 891 which has the HDMI 1.4 version and is selling for a reasonable price. The other two receivers mentioned although being very good ,don't have the HDMI 1.4 which was one of your criteria.
Re: Receiver advice
07-20-2010 06:49 AM
Sorry but I just found out that their will be no 3D firmware update issued for the Yamaha 6280. ![]()
Re: Receiver advice
08-05-2010 02:00 PM
With respect to speakers, check out the Klipsch Reference series. Amazing reviews.
Re: Receiver advice
09-28-2010 09:14 AM
My choice would be Dennon...or Pioneer Elite..you will pay though..I'm sure Dennon has an ethernet port as well. :-)
