Re: Selecting the Right Camera Lens
If you are starting out, a 24-70mm, 70-200mm, and 50mm will be all you really need. A cheaper camera is fine as well, your lenses will last a lifetime but your camera will most likely be upgraded over time. Buy what you can afford and buy for what you are shooting. Lighting is important as well, you will need a good flash.
