Is Rogers Samsung Galaxy S7 edge 32GB Smartphone compatible to hearing aids
Looking for a cell phone $0 that is compatible to hearings aids
Re: Is Rogers Samsung Galaxy S7 edge 32GB Smartphone compatible to hearing aids
What do you mean compatible with hearing aids? Could you explain and I am sure we could help you find one that will work for you
I wear heariing aids, so I don't want static noise when using the cell phone as the handfree phones do.
The galaxy S7 has a hearing aid compatiblilty rating of  M4/T3
Does that help?  I am not to familar with the rating system but I can look into it if you need
