Cell Phones
- Cell Phones
- Cell Phones
- UMTS?
UMTS?
02-11-2012 08:53 AM
Would an unlocked phone that has these specs work on Telus?
- Tri-band 3G UMTS 2100/1900/850/800 Mhz
- Quad-band GSM/GPRS/EDGE 850/900/1800/1900 MHz
Is UMTS and HSPA the same? Will I get the same speeds as buying the same model in Canada?
Re: UMTS?
02-11-2012 09:36 AM - last edited on 02-11-2012 09:45 AM
Yes this unit would work. When dealing with 3G compatibility "Robelus" and AT&T, the bands you'll need to look for are 850 (band V) and 1900 (band II).
There are technical differences in the terms UMTS and HSPA. I'm no wireless technical expert, but my understanding is UMTS is the original 3G specification (Release 99), while HSPA (in itself divides into HSDPA and HSUPA for download and upload connections respectively) is an enhancement to UMTS for achieving higher data bandwidth. (I believe the bandwidth is measured in Kb/s in the original R99 specs; now you'll get 42Mb/s with Telus dual cell HSPA+.)
It's like the original GSM specification, and EDGE is enhancement to GSM in terms of data transfer (higher bandwidth).
However, most consumers or marketing departments of the carriers use the term interchangeably.
As for whether you'll get the same speed as you'll buy a device in Canada, that will depend on the device you are comparing it to. For example, an iPhone 4S will never "achieve the same speed" from a technical perspective if you compare it with the Samsung Galaxy S II X, because 4S has a max. speed of 14.4 Mbps, while the SGSIIX - because it implements dual cell HSPA+ - can achieve up to 42 Mbps. And both can be purchased here in Canada from Telus. OTH my Nexus One can do 7.2; same as iPhone 4.
Re: UMTS?
02-11-2012 12:40 PM - last edited on 02-11-2012 02:50 PM
With regards to speed... In both cases I'm looking at the Blackberry 9810. However, I want a customized 9810 that's not Telus. Are all 9810's the same electronics?
So with the UTMS specs, would I get the full HSPA+ speeds with a Telus SIM?
Re: UMTS?
02-11-2012 07:56 PM
There are two versions: one is AT&T/"Robelus" (which is the one you stated) and the other is Wind/T-Mobile (according to Wind's specs, their version has 850/1900 ripped out and implemented AWS instead). If you are in foreign land, it is possible that they offer the AWS version instead. (For example, the version of Nexus S Samsung offered in Hong Kong is the T-Mobile/AWS version, even though the Robelus version also supports 2100 - the band used in HK.) So you have to be careful of which one you are getting. I don't have a BB myself, but if you look at the about and/or settings menus, it lists the bands that the device supports. So check to make sure that unit supports 850/1900.
I'm not sure which revision of HSPA the 9810 implements, and the specs on RIM's website didn't specify. Unofficial/blogger sites all seem to say the 9810 has 14.4 (which means technically speaking it's the same as iP4S).
