Charging an HP netbook in Europe
Hello, I have HP mini 110-4100 netbook from future shop from Canada and Im going back to Europe (Slovakia), what I need for charging my netbook? I mean f.e. simple adapter, transformer, voltage converter or something else? I will use long time.Thanks.
Re: Charging an HP netbook in Europe
As long as the power supply is a switching power supply and shows that it supports the Europe voltages then all you need is an adapter to change the plug to fit in the wall outlets
Check the charging brick. If you see 220 or 240v.... You will be fine. You may even notice it charges faster.
Yes, expect to need an adapter. If you have a lot of North American devices, you may wish to get a universal power bar.
