The Captain
Re: How do I get internet explorer to work? I am connected to wifi but its still does not work.
Windows xp Vista & windows internet explorer 7
If you know anything that would work I'd appreciate it. Thank-you.
Legendary Luminary
Is it "Windows XP" or "Windows Vista"?
(There is no such thing as "windows xp vista".  "Windows Vista" is a subsequent version of Windows after "Windows XP", which itself has been superceded by Windows 7, Windows 8, Windows 8.1 and Windows 10.)
The Captain
The computer runs on windows xp - it just has a sticker on the computer saying vista basic
Windows XP and internet explorer 7 are both no longer supported, your best option is to look at upgrading
For the cost of the upgrading Windows and the age of the computer.  It will be better to get a new machine.
