Model #: GMA8540INC Web Code: 10642053
Hi,
What is the chipset and mother board model?
Is the liquid cooler factory sealed with push pull flow?
What is the SSD brand and model?
What is the 2TD HHD brand and model?
What is the Video Card cooler model?
Is the power supply module and brand name?
Thanks
Re: Model #: GMA8540INC Web Code: 10642053
You would likely need to direct those kind of questions to the manufacture
Agreed, I'd reach out to Cyberpower as that sort of specific detail will likely not be found online.
Typically computer assemblers (like Cyberpower) would not divulge that type of detail.
Their products are sold as products and they reserve the right to change them at any time as long as they are tested to meet quality control.
If you are looking for that type of detail, you should probably consider building your own PC using parts from Best Buy.
