Community Manager
PC multiple monitor display
Hey!
I know that when using multiple monitors, you can set each individual monitor to a different resolution, but is there a way to set the display size of the text (under control panel > appearance and personalization > display) to a different size for each monitor? I've been told that it is not possible. Are there any ways around this?
Thanks!
BBYTerence
Community Coordinator
Re: PC multiple monitor display
What Windows are you running? You can certainly do that in windows 10, I unfortunatly dont have anymore dual screen windows 7 machines to test on
Community Manager
I'm currently running Windows 7.
Good to know that Windows 10 can achieve that though.
BBYTerence
Legendary Luminary
Yes, you most certainly can set independent display resolutions of a multiple monitor setup in Win 7.
@CtrlAltDel  @BBYTerence  isnt looking for individual resolution he is looking to increase the text size
I'm no computer expert, but I don't think that you can set different font size on 2 different monitors using the same video card.
Any changes to font size will affect both monitors when using a single video card output.
I hope @Computers_Mike can confirm this .
Can we interest you in a 2nd. computer @BBYTerence ? Smiley Wink
Hey team,
For Windows 7 as far as I know you cannot set individual text sizes. As that is system controlled, only the resolution can be changed independently.
Legendary Luminary
Okay... yes, text size on Win 7 a system-wide setting and cannot be changed.  You'll need to upgrade to Win 10.
http://www.pcworld.com/article/2953978/displays/use-windows-10s-individual-display-scaling-to-perfec...
