ConnectPro Car Audio Services
- ConnectPro Car Audio Services
- Hello, my subs only work for a minute or two after...
Hello, my subs only work for a minute or two after I tur...
02-07-2012 04:46 PM
Hello, my subs only work for a minute or two after I turn my vehicle on. I have the mtx dual subs with 1600 watt max in the ported box matched with a 1200 watt mtx amp. I got it all in at futureshop vernon. Ive checked the connections theyre good
Store: Brantford
Re: Hello, my subs only work for a minute or two after I tur...
02-14-2012 01:23 PM
If it was installed at Future Shop then all you need to do is bring the vehicle back to them and they will troubleshoot the problem for you. Workmanship is warrantied for lifetime of the vehicle, and products usually a minimum of 1 year, or up to 4 years if you purchased the service plan.
Brandon Insley
ConnectPro Car Audio Lead Technician
Future Shop Store #620
Brantford, Ontario
Brantford, Ontario
02-17-2012 07:27 PM
Is the amp turning off? or overheating very quickly?
is there a trouble type light on the amp? check they manual for how to read the lights on the amp to troubleshoot.
I'd try hooking up another speaker to the amp, and trying it at low volume to see if the sound cuts out. Then you can rule out the amp or the speakers as the problem
