ConnectPro Car Audio Services
- ConnectPro Car Audio Services
- Nordic 2-way remote starter functioning as 1-way
Nordic 2-way remote starter functionin g as 1-way
11-01-2011 11:14 PM
I purchased and installed (through futureshop) a Nordic 2-way remote starter about 4 or 5 years ago (with extended warranty which seem to have expired) and it's worked relatively smoothly with some issues early on that FS resolved. However, the problem I have now renders the 2-way feature useless as the 'brain' no longer sends a signal back to the remote verifying neither the start status nor the door lock status. The remote does work as it does lock/unlock and starts the vehicle, so I'd rather not pay for a new product and installation. The brain was swapped out a couple years ago under a recall - no issues since the swap until just recently. Any thoughts would be appreciated - Thanks.
Re: Nordic 2-way remote starter functionin g as 1-way
11-02-2011 07:17 AM
Could be just a bad remote or antena bring it into a future shop to reset the whole unit and re program each remote if that doesnt work they will just have to do elimination by trying to program a new remote to it and so on...
11-02-2011 07:28 AM
Berger is most likely correct.
I'd have your ConnectPro shop check out the antenna wire for kinks and loose connections (at the brain, and at the antenna).
Also try a different brand of battery inside the two-way remote. Very rarely but sometimes that is the culprit.
When the remote is opened to replace the battery, look for signs of corrosion or humidity effects or a weak solder point.
Also try programming a 1-way remote first then the two-way. Then try it the other way around. Funny, but sometimes this will work.
11-02-2011 05:25 PM
Thanks for the input Berger.
11-02-2011 05:25 PM
Thaanks. I'll give that a try.
