andyd
BLU-RAY PLAYER SOUND ISSUE
I currently have a Sony Projection TV capable of 1080p HD.  Tv is hooked up to Sony Receiver with 5.1 Surround Sound.  Recently purchased a SONY Blu-Ray Player.  Got it home and realized the TV only had a DVI port.  Went back to Future Shop and purchased a HDMI - DVI Adaptor.
Hooked everything up and while picture quality was superb the sound quality was slightly better than what you get from a TIM HORTON'S drive thru speaker.  The sound came out very distorted.  I read somewhere that DVI only carries a video signal and no audio.  The audio connections are still running from my receiver to the TV.
Starting to think I may have to return the BLU RAY PLAYER since the sound quality is terrible.  Of course with me being electronically challenged I may have done something wrong.
any thoughts?
sonimax
Re: BLU-RAY PLAYER SOUND ISSUE
In fact, the sound of a BD player should be better than a regular DVD player.
What type on connexion did you use to transfer the sound of the BD player to your receiver?
Trust your senses, not the numbers...
Over 6,000 post
In the "forum français".
andyd
The only sound connection I had was coming from my current DVD/RECEIVER into the television.  The sales person at Future Shop didn't mention I'd need anything new for the audio in order to make the Blu-Ray do what it's supposed to do.
What is it that I would need?
sonimax
First, if you want the sound of the BD player to come out from the 5 speakers hooked to your receiver, you need to transfer the sound from the player to the receiver.
Do your receiver has a HDMI input? If it don't, you should use a digital audio input of some sort like an optical or coaxial input.
Over 6,000 post
andyd
My receiver doesn't have HDMI but does have an optical port.
So all I need is an optical cable which will connect from my receiver to the Blu-Ray?
My surround sound won't be affected?
