ConnectPro Home Theatre Installation
seanp
how do I connect my home theatre to my tv and ps3 so I g...
how do I connect my home theatre to my tv and ps3 so I get the speakers to provide sound for all (samsung Plasma 3d #PN51D550-PANASONIC HTIB #SCBTT270K AND PS3 -320GBWITH PS MOVE?
Honour Roll Member
debaser17
Re: how do I connect my home theatre to my tv and ps3 so I g...
Personally I do it by running HDMI cables from my cable box, PS3, & Xbox into my receiver, then a single HDMI out from receiver to TV. That way switching video source on the receiver inherently switches the audio source too. Is this an option for you? How do you have it set up now?
seanp
I haven't set it up yet as I was uncertain, I have one hdmi port on back of receiver, its a HTIB (home theater in a box) so its not a very expensive unit, so how would I connect my ps3 to the receiver (hdmi)?
If so then how do I connect the receiver to the tv? Do I need to get something else to assist in this process?
Honour Roll Member
debaser17
Just one HDMI port? Is it in or out? That's odd, I would think it would have at least 2, an in and an out...
You could connect your PS3 to the tv via hdmi for video, then use another cable to connect it to your receiver for audio, such as an optic cable. Then you would just have to switch the source on both your tv and your receiver when going back and forth between cable tv and ps3...
Honour Roll Member
debaser17
Ok I see it has one HDMI in, so it must have an HDMI out as well. So you could do the above, using the HDMI in/out for your cable box, and another input for the ps3. Optic is the next best to HDMI, does it have an optic in? Then it would just be a few additional bucks for the optic cable.
Trusted Expert / Community Ambassador
Atomic
Your receiver only has one HDMI input and one Toslink/optical input.
The only way to do this would be to connect your PS3 via HDMI to your TV and then wire your TV's optical audio output to your receiver's optical input.
It will be a little funky, but it will work.  You will have to control your PS3 audio by changing it in two places, rather than one (your TV to select PS3 video, and then your receiver for PS3 audio).
Don't know if you really need the 3D Blu-ray player since your PS3 already does that and more.
Also, you would need to have your TV on even if you are not using it.  For example, if you want to listen to music (from a CD) via your PS3, your TV will have to be on in order for your receiver to get the audio signal.
Any additional devices, such as XBox, Wii, Satellite or Cable receiver, should also be connected via HDMI to your TV rather than your receiver.
Good luck!
