GPS, Car & Marine Electronics
- Need instructions to re-activate Nordic NAHTDK4 re...
Need instructio ns to re-activat e Nordic NAHTDK4 remote car starter. ..
02-02-2012 03:09 PM
Hi - looking for help. I have this starter, it works before but now it doesn't work anymore,I already checked battery,it is fine,so I need to re-activate Nordic NAHTDK4 remote car starter.Can I ask for a copy of the manual through Future Shop? I am in Edmonton Alberta.
Thank you so much
Store: Brantford
Re: Need instructio ns to re-activat e Nordic NAHTDK4 remote car starter. ..
02-14-2012 01:16 PM
Honestly your best bet would be to stop by your local Future Shop and have it re-programmed. It usually only takes a couple of minutes (assuming it is just a re-program, everything was installed properly and the hood pin isn't broken or corroded). If it turns out to be a more involved problem, the technician can advise you of what steps to take in order to get it working again.
Brandon Insley
ConnectPro Car Audio Lead Technician
Future Shop Store #620
Brantford, Ontario
Brantford, Ontario
