GPS, Car & Marine Electronics
- replacing old remote starter
02-08-2012 04:18 AM
Re: replacing old remote starter
02-11-2012 03:04 PM
Hi Justin,
I always recommend going with a brand that we sell because they're brands that I trust and am familiar with. That, and any warranty-related issues that require labour are covered by us (i.e. we need to swap out the brain for some reason). If you purchase from somewhere else the workmanship is covered, but if there any product-related issues, you will likely be charged if we have to remove the unit or swap parts.
As far as ease of installation goes, it's a case-by-case basis. Just because there is already a remote starter installed doesn't necessarily mean it's easier for us to replace it with another one. In fact, sometimes the opposite can occur depending on the quality of the existing install. Hope this helps!
ConnectPro Car Audio Lead Technician
Future Shop Store #620
Brantford, Ontario
02-17-2012 04:54 PM
If you want futureshop to install the starter. Then get a nordic brand starter
To me it sounds like the previously installed starter may have installation or wiring issues.
What was the problem you had with the prostart? I'd have the connectpro tech check that out first before you put another one on top of it
