arushan
HDMI HELP
How do i know which HDMI cable will fit into the back of my tv's HDMI slot? Or are all of the same size?
larry777
Re: HDMI HELP
They all use the same end design to fit a standard HDMI slot. The HDMI cable version may be a consideration to watch out for as version 1.3 and 1.4 have more cabability than the 1.1 and 1.2 versions. As an example version 1.3 will support deep color and would be used with version 1.3 A/V Receivers. Version 1.4 will be used with the newer 3D HDTV's comming out along with the newer 1.4 version A/V Receivers.
seeAvneet
Re: HDMI HELP
HDMI cables are the same size. They only differ by speed (GBPS- GigaBytes Per Second) and version (1.3a/b/c 1.4, etc.). Higher HDMI versions can support higher speeds and additional features (as mentioned above, Deep Color and 3D TV support.
________________________________
Avneet - Burlington 070 - Home Theatre
