How-To Videos
- Private Forums
- archive
- How-To Videos
- How-To Videos
- How to install a wall mount for a flat panel tv
07-24-2008 08:21 AM
Laura
Social Community Specialist
twitter.com/FS_Connect
Tech Yeah! For the love of tech!
I can't believe he wired tied the A/V wires to the surfac...
08-18-2008 01:00 PM
I can't believe he wired tied the A/V wires to the surface of the wall. That would drive me nuts and I would be focused on the surface run of wires rather than the TV. Always hide wires in the wall cavity for aesthetics. If you are paying someone to wall mount your TV, ask them if they properly run wires behind the drywall. If not keep looking for an installer that will.
I did notice he ran the wires behind the dry wall in the fireplace installation video, so watch that one to see how it is done.
______________________________________________________________________________
Don't go around saying the world owes you a living. The world owes you nothing. It was here first. - Mark Twain
wat if the walls hallow? what if there is oly about...
08-29-2008 06:06 PM
wat if the walls hallow? what if there is oly about 2 inches of the wall, and i put a wall mount, will my tv fall, or will it hold although its sorta loose?
You should always try to attach the TV mount to a stud or...
[ Edited ]Options
08-29-2008 07:02 PM - last edited on 08-29-2008 08:07 PM
You should always attach the TV mount to a stud as drywall is not strong enough by itself to support the weight. If its loose, I wouldn't take the risk (if that TV falls, you won't be happy).
Message Edited by Krypto on 08-29-2008 08:07 PM
