product knowledge
what is better for backlight configuration:LED or DIRECT LED and display technology, LCDor LED
Re: product knowledge
Welcome to the Best Buy Plug-In forum @carguy007
It's a bit difficult to answer the question as it seems a bit vague.
In what context are you referring to?
As each application is different, each has attributes for specific applications or niche, so "better" is dependant on use.
I'm comparing tv's. They're both 1080P but like my post states, one has LCD and the other LED. I don't know which one of the two is better
hello...all...!!
First, to get some terminology out of the way, LED stands for light-emittng diode and LCD stands for liquid crystal display. Along with plasma televisions, LED and LCD-powered televisions make up the lion's share of the next-generation of home entertainment.
To start with LED televisions, televisions powered by this technology tend to be highly efficient yet can scare some potential customers away by a higher initial price. The contour and size of the screen does not have a major impact on the efficiency of LED technology.
An LED or liquid crystal display is chock full of tiny crystals, as the name implies. Most LED televisions have greater black levels and very bright white tones, especially compared to older televisions with a fluorescent backlight. LEDs are considered the most energy-efficient televisions on the market today, even nudging out plasma and LCD televisions, and LEDs are known for their outstanding contrast ratios.
Televisions powered by LED technology tend to dim slightly over time rather than crash and burn in an abrupt outage. Dimming the backlight on LED televisions can help to lower the energy usage of the set.
Many television manufactures over the years have taken to melding the terms LED and LCD into LED-LCD televisions. This is because most of today's LCD televisions utilize an LED backlight rather than a fluorescent backlight.
Having an LED backlight increases the television's contrast and gives a more accurate representation of thousands of colors. This makes LED-LCD televisions more energy-efficient and vibrant-looking.
As a rule of thumb, if an LCD television doesn't mention "LED" on the box, then the LCD television is probably powered by a cold cathode fluorescent lamp (CCFL) as a backlight, which might be underpowered depending on your entertainment needs. An LCD television, though, is typically the frontrunner compared to plasma televisions of LED sets in terms of price.
An outstanding picture can be had with an LCD television for around $250 and the screen itself is very bright, compact and energy-efficient. If you're on a budget, an LCD television can provide vibrant color and screen uniformity at a fraction of the cost of plasma or LED televisions. home is important part of our life make it beautiful.
LED televisions actually tend to be more expensive than LCD sets. Another drawback to LED sets is that over time these televisions could suffer from uniformity issues, or a lack of clear vibrancy across the entire screen. The black levels on LED sets has also received some criticism - LED televisions typically amplify the whiteness to increase the contract ratio thereby compensating for any deficiency in black levels.
For sheer motion performance, plasma televisions often get the highest marks. A plasma television utilizes plasma pixels filled with gas and powered by electricity to ensure that every single pixel is separately controlled. This makes plasma televisions by far the more controllable option.
For black levels and lightning-fast refresh rates, plasma televisions also eke out a victory over the competition. Other aspects in which plasmas really shine are in contrast ratio and viewing angle; which means that everyone will be happy, regardless of seating, watching the big game at your house.
One potential drawback to a plasma is that, because of engineering quirks, a plasma set normally has to be larger than 42 inches. Plasma sets are also considerably heavier and more ponderous than LCD sets, and also more expensive.
thanxccccc...........hope this will work...Smiley Wink
