Do products purchased in the U.S. accepted under warranty in Canada?
If I purchase a TV or entertainment system in the U.S., will Canada honour the warranty?
Re: Do products purchased in the U.S. accepted under warranty in Canada?
Hi there,
are you talking about from Best Buy or a competitor?
If its from Best Buy and you purchase the Geek Squad Protection from the US - they do offer international coverage but you will need to follow the specific guidelines on how to submit a claim, as they differ from what they do here. This would be explained on the warranty contract.
If you decide not to purchase an additional warranty service the manufacturers warranty will likely not be international.
Regards
I agree with Mike.  If you are talking about the manufacturer's warrranty, a US product is not typically covered in Canada.
If you need to file a claim or return, you will likely have to ship it back to the US.
