Will my LG EG9100 work in Europe with digital inputs like Netflix?
I know there are power/voltage issues, but if Im not using traditional cable boxes, will the PAL/NTSC compatibiity be an issue?
What's the best way to handle the power adapting?
Re: Will my LG EG9100 work in Europe with digital inputs like Netflix?
Hi @DavidWeiner, welcome to the Best Buy Community Smiley Happy
I don't think the HDMI inputs nor smart features like Netflix will be a problem, the issue as you noted, is power and frequency (220V @ 50Hz), and in this case I would recommend buying a TV in Europe, as opposed to modifying the power supply of your TV.
Great choice in TV BTW.
Hi @DavidWeiner, I just noted a brochure for the EG9100 series, which notes it's dual voltage.
So, it may very well be a matter of replacing the power cord,or using a plug adapter.
This can be verified by information on the back of the unit, which will note power consumption and power requirements.
If you see 110-240 50/60 Hz. it's a matter of changing the plug type. However if you only see 110V @60Hz. it's only designed for use in North America.
