tv box
Hi there,
I have a my gica 495 atv pro tv box and its remote does not work after I reset it although sohows the batteries are fine and have power. I did everythng found useful related to this isuue but so far with no succes.
What's the issue here? If anybody has such experience , please share
Thank you
Re: tv box
For Pairing KR41:
KR41: Keep hold VOL+ & Page+
Then Plug in USB dongle into box and press buttons till the light stops flashing on the remote.
If you are using a different remote you can always check out: http://wiki.mygica.tv/index.php?title=Main_Page You can click on the remote and usually at the bottom there is a link on how to pair
Cheers
