- TV
- 32" Toshiba (32DT2U) #10175596
01-16-2012 07:05 AM
Re: 32" Toshiba (32DT2U) #10175596
02-25-2012 07:37 PM
Ours is doing the same had it since November. DId you figure out the problem?
Thanks
02-25-2012 08:02 PM
There is not much you can do as a consumer at this point.
If you haven't already, try the TV in another outlet in the house, or even an outlet at a friend or relative's house. It may be a problem with your outlet.
However, failing that, you likely have a power supply issue as your TV is not getting the power it needs to stay on.
If your set is no longer under warranty, take it to a TV repair shop and ask for an estimate. It should be a relatively simple task to fix, but you can't be 100% sure without looking at it.
Alternatively, save the money from the repair and buy a brand new set.
