Announcements
Best Buy and Future Shop are consolidating as Best Buy. This means the products, services, and features you have come to expect from Future Shop and FutureShop.ca will now be available at Best Buy and BestBuy.ca. We have plans to invest up to $200 million to build a leading multi-channel customer experience on the Best Buy brand.
Visit futureshop.ca for more details & click here to learn more about what this means for the Tech Yeah Community.
Please visit the Best Buy Plug-in TV & Home Theatre forum to get your questions answered.
How do I hook up a Blue-ray DVD player to my HD TV to get Netflix ?
How do I hook up  a Blue ray DVD player to my TV to get Netflix ?
Re: How do I hook up a Blue-ray DVD player to my HD TV to get Netflix ?
Hmm...
  • typically Blu-Ray players just need an HDMI cable to work.
  • NetFlix is a video streaming service.... it does not work off a disk.  Video stream is available directly on some TV's without needing a Blu-Ray player.
  • Is the TV connected to your wifi or internet?  Is the Blu-Ray connected to your wifi or internet?
  • what is the exact model of your TV and Blu-Ray player?
If your BD player supports Netflix, you will need to connect an HDMI cable from your BD player to your TV and an ethernet cable from your service provider to your BD player.
Otherwise, if you have WiFi, you will have to set that up in your BD player.  That should be it, but you should check your User's Manual to be sure.
