- TV
- How do edge-lit LEDs brighten the centre of the sc...
How do edge-lit LEDs brighten the centre of the screen ?...
05-14-2010 09:05 AM
How do edge-lit LEDs brighten the centre of the screen ? Is there additional backlighting in the center ? Is it dynamic (local dimming) ?
Re: How do edge-lit LEDs brighten the centre of the screen ?...
05-17-2010 09:07 AM
All LCD's use a layer of plastic that diffuses the light, thus spreading it across the panel.
Look at an ordinary frosted light bulb vs. a clear light bulb: you can see the filament inside the clear bulb but in the frosted bulb the entire bulb surface lights up as the frosted coating diffuses the light across its surface.
Set that are fully backlit, have the LED's spaced across the entire panel, not just along the edge. Each individual LED can then be brightened and dimmed, hence the term "local dimming". This allows for higher contrast levels and more even light diffusion.
