jts_360
LED TV Question
I am considering this to be my new TV purchase, Samsung 55" led TV
http://www.futureshop.ca/en-CA/product/samsung-55-1080p-120hz-led-hdtv-un55b7000-future-shop-exclusi...
my question is, in the specs it says it has an optical digital audio output, is this output for HDMI signals that are sent to your tv so you can send it to your home theatre or is it for over the air signals that come 5.1?
Re: LED TV Question
Here is the relevant information from the product manual:
"When the Home Theater receiver is set to On, you can hear sound output from the TV’s Optical jack. When the TV is
displaying a DTV(air) signal, the TV will send out 5.1 channel sound to the Home theater receiver. When the source is a
digital component such as a DVD / Blu-ray player / Cable Box / Satellite receiver (Set-Top Box) and is connected to the
TV via HDMI, only 2 channel sound will be heard from the Home Theater receiver. If you want to hear 5.1 channel audio,
connect the digital audio out jack on DVD / Blu-ray player / Cable Box / Satellite receiver (Set-Top Box) directly to an
Amplifier or Home Theater, not the TV."
