- TV
- Sharp TV No picture, just sound
12-29-2011 05:42 AM
Turned on Sharp 37" this morning, just sound, no picture. The Mute and Volume display works, but no Guide or Info. I tried the DVD player and it works fine. I made sure the TV is on channel 3 or 4, still no picture. I unplugged the power to everything for 5 minutes, still nothing. All wires are plugged in correctly. What is the problem?
Re: Sharp TV No picture, just sound
12-29-2011 06:46 AM
Sounds to me like there is either a sevice disruption in your cable, or there is something wrong with your cable box. If it was the TV itself, you would not be seeing any picture at all (including the volume display). How is your cable hooked up to your TV? What cables are you using. Is it possible to use a different input? If so, have you tried that? Sounds like it could be a problem with either your video cables or your cable box itself. Have you tried contacting your service provider?
I know, a lot of questions, but we'll need some more information if you want us to be able to guide you in the right direction.
Thanks for the question
