Smart TV Upgrader
Can I get a wired or wireless keyboard and mouse that will hook up to my LG ST600 Smart TV Upgrader ? If this is not possible is there another model of upgrader that will hook up to a keyboard ?
Expert (TV)
Re: Smart TV Upgrader
There is nothing you can hook up to the LG upgrader. The Boxee Box comes with a remote that has a Qwerty keyboard on the reverse side. Some of Samsung's Smart TV's have web browsers and a Qwerty remote is available or included with their proprietary system.
Or you use some other media streamer such as a Wifi enabled blue ray player and purchase a bluetooth keyboard and mouse for your computer.
The LG Smart TV Upgrader actually is compatible with a USB keyboard and mouse for a little more functionality. Hope that helps.
Expert (TV)
Apparently I've tried the wrong brands. :smileyfrustrated:
Some keyboards apparently do work, although it seems that people have had success by using a USB hub plugged into the smart upgrader and then the key board plugged into the hub.
