Sony wireless headphones MDR DS6500
Are subject headphones suitable for use with sharp flat screen Aquas  High Def TV ? If so how is connection made?
Re: Sony wireless headphones MDR DS6500
Welcome to the Best Buy Community Plug-in Forum @Knsgee Smiley Happy
Yes, you can use the Sharp Aquos TV with wireless headphones.
The Sony MDR DS6500 wireless headphones can be connected using either a digital optical cable which is supplied, or analogue RCA inputs.
Most all TV's feature an Optical digital audio output, and in many cases a 3.5 mm Analogue audio output which can easily be converted to RCA with an adapting cable.
I would also recommend the Sennheiser RS165 headphonesHeart, as they also feature the ability to transmit to 2 headphones from the same transmitter.Smiley Wink
