Apple Air Pod
Hi, I'm wondering Best Buy Canada will be stocking the Apple Air Pods anytime soon?
Legendary Luminary
Re: Apple Air Pod
They are now released and on the site, Web code is 10557542. If you enter that number into the search bar it will pull them up. You can call you local store and give them that number as well to see if they have reviced any stock.
