chs
Return Jaybird X2 headset?
Hi,
    I purchased a set of Jaybird X2 earphones, but absolutely none of the earpieces fit my ears comfortably; the the medium and larges pop out for being too large and the small ones pop out for being too small. Is there a way to return these? I'd hate to think I just burned $120 on something that I can't even use.
Re: Return Jaybird X2 headset?
Unfortunately headphones are un-returnable once opened.  You could try contacting the manufacture to see if they have another size of earpiece.
